problem with ariston washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum problem with ariston washing machine
  • #11586
    I have a ariston 2000 A1435 the problem I have is that it stays on the wash programe and nevr moves on to rinse and spin etc i had a problem with the pump and I have now fixed that is there anything that this may have caused to affect the wash cycle it does not seem to draw hot water but I am not shure if it is just me mucking it about. where is the temp sender and any test that i could do to chect this would be great 😥
    #145901
    Re: problem with ariston washing machine
    If there is a fault with your machine usually the red light on the panel will flash rapidly in sequence to show the ‘error code’. (by counting the rapid flashes between the longer pause)
    Beyond that, it really could be anything :con:
    I would recommend a local independent repair call in and have a look at it for you via this link: Repairs@
