Problem with ASKO 20003 washing machine (drain pump)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Problem with ASKO 20003 washing machine (drain pump)
Viewing 15 posts - 1 through 15 (of 29 total)
  • #69677
    Ali_baba
    I stupidly shorted the live and neutral connections to my drain pump and fried a transistor on the circuit board to the extent that I can’t see the details so as to know what to replace it with. The pump now runs constantly (as soon as the power button is switched on), so if anyone has a diagram or knows what the three-leg transistor at position Q307 on the control unit pcb for this model is I would be very grateful. Failing that if there is a generic type of transistor that I could use on a 230v system such as this I’ll try that instead.
    Thx in advance
    #375605
    Re: Problem with ASKO 20003 washing machine (drain pump)
    The info I have likely won’t go to that level I’m afraid. It would detail the PCB and connections to it etc but not down to component level.
    Ali_baba
    I’ll take anything you’ve got ! You never know, it may well help.
    #375607
    Allsorts
    Can you give me the board reference… or any other numbers or references on the board?
    George
    #375608
    Ali_baba
    Hi and thanks for the reply.
    The info on the board –
    “Emerson Electric Electronic Speed Control Division”, “Assembly No. 2514” followed by “20”, “Rev.G”, “Date Code – 0796” then “EA31190”.
    On the reverse (solder) side is “EPN 251501 Rev.D” printed into the PCB.
    And it looks like this –https://picasaweb.google.com/lh/photo/vlRH1ep4cx3C21iAVxvJt9MTjNZETYmyPJy0liipFm0?feat=directlink
    The fried transistor is directly below the big yellow capacitor.
    #375609
    Ali_baba
    Shameless self-bump
    #375610
    There is no info on Asko’s system for that machine anymore I’m afraid so it must be well over 15 years old I’d expect but probably much more, if the model number is correct and it is a UK model.
    There is a later 2005 model but it won’t use the same spare parts or, certainly not that control module.
    Martin114
    It will be a Triac – probably same as the ones on the top in a row
    #375612
    Ali_baba
    Nice one, I’ll get hunting for a Triac transistor then.
    One thing though, it has a larger heatsink than the others in the top row (which are all marked either IRF740 or IRF 840), would that make any difference to what I needed to ask for please ?
    #375613
    Martin114
    Ah it won’t be the same then. The IRF’s are Mosfets.
    edit..
    What are numbers on the three devices at the top left of the board?
    #375614
    Ali_baba
    thx again for the input.
    You may have to be a bit more specific than ‘the three devices at the top of the board’, but if you mean the 3 transistors then the 2 to the right hand side (grouped together) are 3-legged transistors with IRF 840 marked on them and the one standing on its own to the left is a two-legged transistor with HFA08TB marked on it.
    Maybe this shot of the transistor / MOSFET might help
    #375615
    Martin114
    Sorry then I can’t be much help to you on this one
    #375616
    Ali_baba
    Thx for trying anyway.
    If I could pick your brains a bit further though, would you think a generic transistor that might be suitable or will it something specific to this application ?
    #375617
    Martin114
    I would say the only way here is to hope someone has a board and can id the component for you, sorry.
    #375618
    Ali_baba
    There wouldn’t be any way to tell what it is by removing the component and measuring the resistance (or something else) between the legs ?
