It seems that the thermostat sensor is not working correctly. When the fridge/freezer is plugged in, the motor starts fine, the fridge/freezer cools down to the required temperature and the motor stops once it reaches the required temperature as it should. However, the problem is that once the temperature rises again, the motor should start up again to cool it down but it doesn’t. The only way to start it up again is by turning it off and turning it on again. Do you know what the problem is and how it can be fixed?
Hope you can help.
Bernard
