Hi I have a problem recently after I defrosted the freezer.
Previously I had the fridge setting to 5 and water would form and run down the back of fridge and freezer got a large amount of Ice.
After switching back on with the setting to less than 1.
as soon as you switch it on the motor starts running.
Ice forms in the back of the fridge. I have tried defrosting the fridge again but after 1-2 days Ice is all over the top of the fridge and also on the right hand side just over the water runner.
The green cleaning peg is free and as far as I can see the hole is not blocked.
what stat would be required for this model if you think that is the problem
purchased about 2003
Model ER78311
Type B256940
Prod 925 684 601
Serial 2010 0358
