Just wondered if anyone else has come across this problem?
When fitting a new door (pt No. 052569) to an old Ariston FV37GB-(WH) I found the fittings on the inside of the door on the right hand side are about 3mm lower than the left.
This means the door handle doesn’t fit straight at the top of the door and the r/H hinge won’t fit between the clip and the bottom of the panel.
Connect have sent out replacement doors but on measuring they look as if I’m going to have the same problem.
I have spoken to Connect who say they haven’t had any other problems with this stock!
As far as I can tell this is a manufacturing fault, has anyone else found this?
