Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › problem with hotpoint lst216a dishwasher
- This topic has 8 replies, 2 voices, and was last updated 3 years, 11 months ago by
Ryoken_1972.
May 7, 2022 at 2:28 pm #100800
Ryoken_1972
Participant[h=2]hello , as title , i have had this dishwasher for 10 years now and its worked flawlessy uptill recently, i normally just use the “rapide” cylce, but now and again use the intensive with cleaning solution , recently however, when i set the maching on a “rapide” cycle. after about a hour (should only last 35 mins) i notice the power button led and the eco led flashing. any one shed any light into this?.[/h] thank you
SteveMay 7, 2022 at 4:51 pm #482253electrofix
Moderatordont know the order of the lights so cant say
we need to know where the lights are in relation to each other
you can look up dishwasher fault codes on the site or post a pic so we can see
May 7, 2022 at 5:36 pm #482254electrofix
Moderatorthink it may be a heater problem
May 7, 2022 at 5:53 pm #482255Ryoken_1972
Participantthanks again for the reply, wife says that, its not a 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} issue it might be ok for a few times then put on the errors, so its a bit intermittent. is there a nailed on test i could try, , just looked and a brand new motor heater element is 40 quid ish , cheers again
SteveMay 7, 2022 at 5:58 pm #482256electrofix
Moderatorrun it and see if it gets hot
if yes then it cant be element
check whether you have it plumbed to hot or cold water as you may think its heating but its not on a hot feed
May 7, 2022 at 6:22 pm #482257Ryoken_1972
Participantjust looked under the sink, there are two pipes, one goes from the cold water pipe, and another one to the sink drain off, so its cold water only,
the 30 minute “rapide cycle is the quickest , ill put it on this cycle and open the door after 20 mins, if its hot inside then the heaters heating the water.
but again it could be a failing unit not a terminal one?.May 7, 2022 at 6:32 pm #482258electrofix
Moderatorheater either work or not
May 7, 2022 at 7:30 pm #482259Ryoken_1972
Participantagain thanks for the reply , i put it on a 30 minute wash, after a bit i opened the door and the water was hot, all though i did notice a weird rythmic noise coming from the bottom of the machine. (sounded like slurping so i suppose thats normal, just never heard it before) , but that could just be me , and the machine did a full cycle no probs. one thing i noticed was the smart meter we got went from
415 watts to 2246 watts while the dish washer was heating , but then the kettle only throws it to 3000, strange what you dont notice, so i think the heaters ok
steveMay 7, 2022 at 8:29 pm #482260electrofix
Moderatoryou will have to watch it and see if it fails to heat next tine it stops
