Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Problem with John Lewis JBLIWD400
- This topic has 19 replies, 2 voices, and was last updated 11 years, 9 months ago by
RichieSounds.
July 22, 2014 at 4:22 pm #81554
RichieSounds
ParticipantHi all – please could you spare a moment to help me; I found that my washing machine would not drain and so as per usual I cleaned the fluff filter (which definitely needed a clean). I reset the cycle and tried to start a new one (having found that the door opened fine) but found that no matter what I do I end up with the ‘Drain’ light coming on and then no activity for a matter of 30 seconds or so… then I hear a sound which I normally associate with the completion of a cycle. No matter what I do I can get the cycle to Start … it just goes straight to Drain.
Does anyone have any ideas of things that I can try to do to avoid calling up Domestic and General (with whom I have insurance) and going through a pedantic process with them involving taking an afternoon or morning off work?! I am reasonably technically competent.
Thank you,
Richard
July 22, 2014 at 4:44 pm #416995Martin
ParticipantRe: Problem with John Lewis JBLIWD400
Call out D&G
July 22, 2014 at 5:30 pm #416996RichieSounds
Is there nothing I can try myself first?
July 22, 2014 at 5:35 pm #416997Martin
RichieSounds wrote:Is there nothing I can try myself first?
Hmmm? To do so would involve intervention within and tampering with the appliance beyond your normal user access may easily void your insurance.
July 23, 2014 at 7:28 am #416998RichieSounds
Can anyone here point me to a service manual for this device?
July 23, 2014 at 9:57 am #416999Martin
RichieSounds wrote:Can anyone here point me to a service manual for this device?
Only available to authorised service dealerships I believe.
July 23, 2014 at 10:16 am #417000RichieSounds
So no one here can indicate what this error might be? Presumably this drain light indicates there’s a problem with the machine. It would be helpful if someone would please indicate what the errors might be. If they are likely to be expensive / lengthy to repair then I would probably replace the machine rather than pursue D&G with their terrible repair turnarounds.
Any ideas would be much appreciated. Perhaps Martin is not the only person who is kind enough to provide a little input?
July 23, 2014 at 12:00 pm #417001Martin
RichieSounds wrote:So no one here can indicate what this error might be? Presumably this drain light indicates there’s a problem with the machine.
Any error detected by the microprocessor shows up in the display window as an E??. (For example a pump error = E20). In the absence of such error codes it could indicate a fault with the microprocessor (I.e The a main power board). So user intervention is NOT advised. Also any earth leakage with components, especially heating elements and main motor can cause spurious faults such as you are experiencing.
So all in all I think your best course of action is to contact the warranty providers, take half a day off and get it sorted. 💡
July 23, 2014 at 5:49 pm #417002RichieSounds
Thanks Martin.
The last time I got D&G involved it took about 1 month to get it sorted. One of their engineers was under such time pressure he nearly had a breakdown and subsequently left the company having not placed an order for necessary equipment (a drain pump) which was necessary to repair my machine. 4 visits were required to get the problem solved which means 4 half days off work. To fix a washing machine.
So A) I wouldn’t really recommend a D&G warranty.
and B) I’d really appreciate it if some professional here could provide any kind of indication as to what the Drain indicator light error I’m experiencing might mean; Martin, thank you for your suggestion that it might be the main board. Do you think D&G or anyone would be able to diagnose further? If it is the main board and in the knowledge that the drain pump failed previously do you think the machine is on the way out and that perhaps I should just buy a new one with a good warranty?
July 23, 2014 at 6:29 pm #417003Martin
RichieSounds wrote:Do you think D&G or anyone would be able to diagnose further?
Yes but only by physical intervention such as I referred to earlier.
RichieSounds wrote:If it is the main board and in the knowledge that the drain pump failed previously do you think the machine is on the way out and that perhaps I should just buy a new one with a good warranty?
It’s best years have long passed, your experience with D&G has been notable for all the wrong reasons (though your story not untypical by any means:( ) buying new would eliminate further sad tales and guarantee a quick resolve I would think.
Anticipating your next question : I favour Bosch/Siemens products though not their washer/dryer as it is made by Smeg (cr*p). Electrolux/AEG/Zanussi washer dryers are still about the only reasonable option. All extended warranties are covered by D&G, an expensive option I would avoid if I were you. 😉
July 23, 2014 at 7:38 pm #417004RichieSounds
Many thanks Martin 🙂
So opt for a machine with a long manufacturer warranty (not provided by a third party).
What about Miele?July 23, 2014 at 7:51 pm #417005Martin
RichieSounds wrote:What about Miele?
Quality personified. 😀
July 23, 2014 at 9:32 pm #417006RichieSounds
Seriously? 😉
July 23, 2014 at 10:15 pm #417007Martin
RichieSounds wrote:Seriously? 😉
Oh yes!
July 24, 2014 at 8:42 am #417008RichieSounds
I think that I’ll have to lower my sights a bit… a Miele washer/dryer seems to be in excess of £1000. I’d like to go no higher than £650 do you think that’s a reasonable budget for a 2-bedroom house with no kids?
