Problem with my PRIMA SINGLE OVEN (857920515512)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Problem with my PRIMA SINGLE OVEN (857920515512)
  • #42864
    gemsbok
    I moved in to a newish house 3 years ago which cam with a single oven by prima. Serial Code and Model looks like a LPR 812/01 (857920515512).
    I’m finding it hard to clean the oven because i can’t see how you clean behind the front glass or above the grill heating element. Neither seem obvious as to how you take the top element out to be able to clean the top of the oven. (we can’t use the grill as you always get a billow of smoke as it heats up from dirt) and how do get the glass out the front to give it a good clean either side?
    Any help would be greatly appreciated.
    #275196
    Re: Problem with my PRIMA SINGLE OVEN (857920515512)
    Door can only be cleaned by removing it from the oven and dismantling it. Grill element is not user removable.
    gemsbok
    Thanks for the advice penguin.
    if i were to take the door off do i go for the nut and bolts on the actually door or unscrew the screws on the main oven frame?
    #275198
    Fully open door. Look at the hinge pivot points – there is usually some sort of flip lever or loop to pop up and lock the hinge with. The door can then be lifted slightly and wiggled off the oven. Useful link with demos HERE.
