problem with Servis 4306s
Home Forums Public Support Forums Help And Support Dishwasher Help Forum problem with Servis 4306s
  • #24383
    Plutox
    Hello
    I am having a problem with my Servis Dishwasher and was wondering if anyone could help.
    Basically, the dishwasher starts the washing programme regularly but soon after it fills with water and starts washing, it stays permanently on the same part of the programme, without moving further – it basically keeps washing on and on, unless we manually make it go one step further in the washing programme.
    Does anyone know what the problem could be?
    thanks
    #201897
    Fairdeal
    Re: problem with Servis 4306s
    Does it heat or drain out the water properly?
    Also is the timer mechanical or digital?
    Regards
    #201898
    Plutox
    If we push the timer forward it will drain, the water heats but not as much as it seemed to do before.
    timer is mechanical
    #201899
    Fairdeal
    well sometimes when the heat sensor does not sense the right temerpature it may stick.
    What about the rinse aid?Sometimes that will give you the trouble.
    The only other thing could be is the timer itself.
    #201900
    Plutox
    thanks Fairdeal, rinse aid is still the same, we haven’t changed it since we had the dishwasher… so I guess it’s either a problem of temperature or timer? Do you reckon it’s going to be very expensive to call someone in to take a look at it?
    #201901
    Fairdeal
    Well first of all how old is it? Is it M4306?
    where do you live,see the repairs section to see if you have a local engineer.It is worth someone having look for sake of a call out(£20ish)
    If it is the heat sensor it will not be that expensive but the timer on its on cost around £70.
