Problem with Siemens Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Problem with Siemens Fridge
  • #20097
    Sati
    Woke this morning to find the fridge not working. Its a large Siemens larder fridge. Part of the model number is erased but its says type K9SR18A EN153 R600a.
    I replaced the fuse etc but it wouldn’t work. I’ve pulled it out and then plugged it in and the compressor/motor comes on and starts cooling but then stops. The compressor is warm but not cooling the fridge!. I unplugged the fridge and left it for a while and plugged it back in and now its working. Not sure how long it will last before it stops though! Also noticed the light flickering yesterday and thats not working today. Could it be an electrical fault?
    #185807
    gegsy
    Re: Problem with Siemens Fridge
    That part model number is not enough to go off Im afraid.
    Sati
    Is the model number printed elsewhere? There’s a sticker on the side with a barcode and a set of numbers if thats any use?
    #185809
    Dave_Conway
    That may be it or inside the fridge next to the salad bin, it will start with Enr 🙂
    #185810
    Sati
    There’s no ENR number on the barcode sticker but there is inside the fridge and it has worn away. Will try and dig out the booklet to see if its on there.
    #185811
    Sati
    There’s no numbers on the Siemens booklet
    The barcode sticker has the following numbers
    06040009061
    KI18R03
    0702 185 798
    GB
    00474863
    760209102386
    0700660
    and the Sticker inside the fridge (which has the ENR number scrapped off)shows
    FD7602 000103
    0702 185 798
    90W 0.7A FUSE A
    R600a 21g
    type KI5R 18A
    Thats all the info I have.
    #185812
    gegsy
    You are going to need a BSH engineer to identify it more accurately as there are numerous models Im sorry.
    Some have mechanical thermostats, some are electronic controlled which I imagine you have, which I think is causing your particular fault.
    Sati
    Where is the thermostat located normally?
    Is it easy to remove as I can’t afford to call an engineer out so I thought I’d take the thermostat out and see if I can get one from the local spares shop.
    #185814
    gegsy
    They are all situated on the inside right hand side of cavity.
    Only the last model in that range has a possible electronic temperature regulator, namely KI18R03GB/03.
    Although it still could be a compressor related fault 😕
