Problem with Siemens se64630gb-17
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Problem with Siemens se64630gb-17
  • #98544
    Specks77
    have a siemens se64630 that fills then just stops . Can then hear a low hum . Only thing I can then do is do a manual reset to then empty the machine … any ideas ? Many thanks
    #472774
    this is an old system so the first thing to check is the motor
    take off the right hand side
    find the main motor and see if its turning
    if yes it will be the main wash impellor gone
    parts arer not too expensive but its a big strip to fit
    Specks77
    Hi Dave ,
    yep motor solid . Thank you for such a quick answer . Motor is solid so assuming it’s that that is the problem . Which given that it was not used for the last 6months will not of helped . Motors look around 180 pounds so given its 18years old might mean time for a new dishwasher .
    thanks again .
    #472776
    how solid it the motor ?
    if it seems to spring a bit then the water seals have a habit of sticking if left unused
    if you spring it back and forth it will normally break free and possibly be ok after that
