Problem with spin on WFO2265GB
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Problem with spin on WFO2265GB
  • #35587
    willda
    Machine is a Bosch Clasic Exxcel 1100.
    Problem: During cycle, programme will stop, spin light blinking, machine hasnt drained.
    So, this happens intermittantly, sometime the machihe will work fine, sometimes it will stop as I described.
    Only way to continue is to empty machine using black Tube. Once empited the machine will spin fine, the drain cycle also works, the impeller twangs fine.
    What I have noticed is that the machine doesnt have a filter, by that I mean, when I unscrew the petrol like cap I can see the impeller..that is, there is only a cavity and nothing there. So I assume that there is actually no filter.
    The thing is, is it possible that something is moving around in the machine, like a coin or something, which is causing this problem intermittantly?
    Assuming a foreign object is boucing around in the machine somewhere, is it plausible that I can easily find it if I open the machine or should I just get someone?
    #247209
    Re: Problem with spin on WFO2265GB
    It might be a lazy pump which works when it feels like it. If there was a coin obstructing the pump you should be able to see it when you drain it manually then remove the inspection cap. To renew the pump you may need to gain access by removing the cabinet front.
    #247210
    Phidom wrote:To renew the pump you may need to gain access by removing the cabinet front.
    …..or to get expert help from a local independent engineer, simply fill in the form from the link here:-
    http://www.ukwhitegoods.co.uk/modules.p … whitegoods
