Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Problems with a Samsung Fridge Freezer
- This topic has 7 replies, 4 voices, and was last updated 18 years, 11 months ago by
Craigsurrey.
May 11, 2007 at 9:45 am #27274
Craigsurrey
ParticipantI have a Samsung side-by-side fridge freezer. A few weeks ago it occasionally made a strange noise that would stop when you opened the fridge door (it sounded like a very noise fan spinning down). The noise has stopped but I am now unable to regulate the fridge temperature. The display was flashing 4 or 5 for a while but when I unplugged the unit and then plugged it in again. it shows 14 or 15 degrees which I am sure is more like it as nothing is very cold. The freezer section is absolutely fine. Does anybody have any idea what this could be? ANy help much appreciated as I don’t want to go to the expense of calling in an engineer without at least some knlwledge of what the issue could be in the first place.
May 11, 2007 at 9:49 am #213338Mac1982
ParticipantRe: Problems with a Samsung Fridge Freezer
Whats the model Craig??
May 11, 2007 at 10:07 am #213339Craigsurrey
It’ an RS21 DGRS
May 11, 2007 at 10:21 am #213340Craigsurrey
Also, I performed a test i was told about involving holding down the top 2 buttons for 10 seconds and the display shows only the bottom-most segment of the far-right numeric LED. If that helps……
May 11, 2007 at 1:52 pm #213341Nutty
Hi Craig
I believe it seems to be the same issue as other people are having in that the fan is freezing up in the back of the unit
:rolls:May 11, 2007 at 1:56 pm #213342Nutty
In fact no sorry it is the thermal fuse 😳
May 11, 2007 at 2:03 pm #213343admin
KeymasterRe: Problems with a Samsung Fridge Freezer
Hi Craig
the bottom segment is the fan failure/jammed fault,it’ll probably need the evap cover or it could also be a defrost problem,more likely the evap cover though to be honest.
Nutty..!! check your fault code sheet.
Bryan
May 11, 2007 at 2:08 pm #213344Mac1982
Damn r600a for there b4 me! 😆
Yep defo sounds like evap cover.
If under warranty call Samsung to arrange a repair :phone:
