Problems with cooling in fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Problems with cooling in fridge
  • #39643
    rejb68
    The food at the back of my fridge is getting very cold, in fact freezing at times, yet the food at the front is barely cold. Also, the bottom shelves get colder than the top ones!
    Does this sound like a fixable problem or am I looking at a new fridge.
    Any help welcome!
    R
    #263042
    Make, model, fridge, fridge freezer? :con:
    smartin
    Re: Problems with cooling in fridge
    crystal ball has stopped working 😆 so make and model number and we might be able to help .
    #263044
    rejb68
    😳 Sorry!
    It’s a Zanussi/Electrolux. Sorry, can’t find a model number anywhere! No freezer compartment, just a fridge.
    R
    #263045
    smartin
    well here goes, could be : door not sealing, light staying on, insulation gone, system blockage, faulty thermostat (if it has), faulty module (if it has) and thats just what i can think of off the top of me head without a model number almost impossible which incidentley should be behind the crisper tray.
    #263046
    rejb68
    It’s a “ZEL 67 W” – does that sound like a model number?
    R
    #263047
    smartin
    yup undercounter fridge , check to make sure the door is sealing ok and internal light goes off as you shut the door
    #263048
    rejb68
    Yep, the light is turning off ok. There may be a sealing issue although it’s hard to check as there’s a ledge above the door; it’s find down the side. The door does seem to slope down a little towards the handle, so maybe I could see if I could tighten it up a bit. Hmmm…
    Many thanks.
    R
