Hi, the power went off in the house whilst using the oven & since then it will not heat up although the fan works fine. Reading elsewhere on the forums I assume the fan element needs replacing? Also, since the power cut when trying to use the grill it starts heating but then starts smoking badly. Do you think I need a new grill element as well or is there another reason why the grill would have started smoking?
