Problems with indesit w101
  • #42472
    AASWALES
    Hello, bit of a strange problem with this one (for me anyhow) the machine sometimes stops somewhere in the rinses and if the gentleman turns the machine off and then back on it continues correctly till the end. there’s no flashing error code at anytime and i’ve done separate tests on the pump, inlet valves and pressure switch with no faults found. Any ideas?
    #273618
    Re: Problems with indesit w101
    Motor stopping doesn’t necessarilly generate a code. Checked brushes?
    AASWALES
    Sorry Penguin45 what i meant was the machine stops completely, it’s like it been turned off. and no i haven’t check the brushes as the machine spin fine with washing in it.
    #273620
    helo_75
    id be checking the plug/socket first
    #273621
    AASWALES
    I did check for that Helo_75 and to see if maybe the door switch was a bit temperamental but all is ok, i have ordered the UKW fault code book in hopes that there’s a something in there that could help.
    #273622
    Quoted from
    http://www.emwelec.co.uk/index.php?acti … revstart=0
    “Common Faults:…
    2.Programme Stuck
    3.Machine dead.”
    Mike.
    #273623
    AASWALES
    Thanks Mike, i thought it would be the board as everything else tested ok , i was just hoping that there was a slim chance that it could’ve been fixed via a reset method or something as the customer has had a real shitty two weeks, he lost his wife then was in a car crash, his combi boiler broke down and know this. Thanks to all, it’s appreciated.
