I bought a new beko frost free fridge freezer two years ago and it’s already caput!
The fridge keeps freezing all my food and unfortunately I have misplaced my receipt. Anyway i’ve seen a similar question pop up but i wanted to make sure mine was the same issue as theirs.
I have a Beko CDA539F-2. Can anyone advise what part/s i need to fix this problem and possibly how to fix it!
hi,
sensor in back of fridge compartment is likely to have failed, if you search this forum with Beko CDA539F-2 in search you will find dozens of people with same problem. sensor is about £10 but you need to cut insulation away at back of fridge. its a easy repair when u know how.
I have a video if that helps.
jskelton555.. That would be really helpful. I’ve tested all the components from the freezer compartment, which seem fine. However someone mentioned, on another forum, that it may be a faulty compressor.
A video would be really appreciative. Does it show the whole process?
