Problems with Servis M6755W washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Problems with Servis M6755W washing machine
Viewing 1 post (of 1 total)
  • #79486
    proxide78
    Hi All,
    We have a Servis M6755W washing machine that has developed a fault.
    When you put it on to a programme, it locks the door and and starts the programme for about 10 seconds and then the light on the panel goes out and after about 5 minutes, the “End” light comes on.
    e.g.
    1. Put it on a spin and press Start
    2. The pump runs for a few seconds and then stops
    3. The light goes out on the display panel
    4. A few minutes later the “End” light comes on
    There is no drum movement through all of this
    I’ve tested a circuit exists on the Element, pressure switch and motor.
    Door lock works fine as it locks and releases.
    My guess is the PCB.
    I can get hold of a PCB at a reasonable price but have read that some PCB’s need special programming/codes entered after installation. Is this true for this model or is a matter of plug it in and it just works? If codes are needed, where can I get them from?
    Hope you can help,
    Jonathan
