Problems with tecnik cooker
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Problems with tecnik cooker
  • #24401
    ibby
    Spent over 1k on it, only used it acouple of times,
    and it has stopped working
    (one oven side)
    model tecnik
    make tkg 1285
    Dual fuel.
    Has any one got any ideas,
    the oven does not come on 🙁
    its over 1 year old.
    #201978
    Re: Problems with tecnik cooker
    Could you expand a little, Ibby? Fan oven? Static oven? Oven dead? No heat?
    Ta,
    ibby
    Well basically, the oevn its self does not work.
    The oven has two sides, left and right, as you can see in the picture.
    The right side works, when you switch it on, (lights turn on, and it gets warm)
    However the left side, which I class as a main oven does not turn on. when you turn the nobs, the lights do not come on. it stays dead, no heat nothing comes out.
    – iam not very good in explaining my self 🙁 – let me know if it makes sense to you now.
    #201980
    gegsy
    Has the clock time been set and is the “manual” hand symbol appearing on display?
    ibby
    gegsy wrote:Hi
    oh man! 😆
    – I feel like noodle now 😆 .
    The actual timer was set to automatic. – so i turned it on manual and its working now, All the lights have turned on 😀 8)
    – Thank you 8)
