I have the above fridge, the starter relay had burnt out I ordered a replacement and at 1st worked well the fridge cooled down to 2deg and started to cycle and maintain temp, after about 30mins the temp started to rise and climbed to 22deg (I then unplugged it)
I have done the following tests.
between windings
22ohm / 23ohms / 45ohms. all windings to earth 6.5m,ohm (standard multimeter)
run current when working properly 1.1 amp
run current when heating fridge. 6amps (over current trips out)
it looks to me the unit has gone into reverse !!!
what would course this and is there a fix?
Thanks, Richard
