Electrolux ESL624 PNC No.911841062.
I replaced the decalcifier (IWMS) because it would not fill properly. That problem is cured now, but the machine fills, then activates for approx 20-30 seconds the stops. It does this in all program modes. Any guidence on this problem would be a great help.
scorpio46
Some of these dishwashers need a conversion kit fitted to them to prevent the anti-overflow problem you describe.
Its a job for an Engineer to be honest & involves changing pressure switch, valves, hoses & fitting anti-interference components in the circuit.
