Programming WMA Boards
  • #60411
    neilsukwg
    Anyone know if WMA boards can be re-programmed to fit a wider range of models than the one it was originally fitted to?
    If so a list of model numbers and the correct programming sequences would be much appreciated.
    Neil
    #342055
    Re: Programming WMA Boards
    Every WMA board will fit several different models, all listed on the sheet that comes with the PCB.
    AFAIK you cannot fit and programme a board that is not specified for a particular model.
    #342056
    neilsukwg
    Thanks Jim
    Had to configure a board yesterday supplied by emw.
    This was achieved by putting the board into programming mode and then refering to a chart to turn the dial through a sequence of letters and button presses to ‘program’ the board to suit the particular model (version 1 or 2) i was working on.
    This got me wondering if all wma boards could be programmed in this way to suit a variety of models.
    #342057
    I carry a 1604321, 1603828 & a 1603557.
    Those three PCB’s cover around 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} or more of the WMA/WMT/WWH/FEW/WA/F range of machines.
    As some machines have 2, 3 or five option buttons they are not interchangable between the different groups but every board will fit several different models.
