Progress/Electrolux dishwasher pnc 91153921800
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Progress/Electrolux dishwasher pnc 91153921800
  • #103116
    HotDog
    This dishwasher fills then goes into drain mode I had the front base plate off there was water in the base cleared water out but still goes on to drain after fill my question is how does this dishwasher measure the water I suspect metering tank blocked I can’t see a pressure switch or an impeller jug trouble is the dishwasher is jammed in due to flooring till customer sorts it is there a circuit board on the metering tank to measure water intake
    #491845
    there is a pressure switch. its very small and attached to the sump
    p sw part no 14000 05 54-08 / 3
    HotDog
    Thanks I am going back tomorrow I’m hoping it’s a blockage in the pressure switch
    #491847
    HotDog
    Blocked in the pressure chamber easy when you know what it looks
