Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › proline dryer
- This topic has 10 replies, 5 voices, and was last updated 18 years ago by
fasetester.
April 8, 2008 at 12:47 am #35846
fasetester
Participanthi guys have to repair a tumble dryer in the morning proline TDV 62. problum drum not turning most likely belt or capactor. does the front or back have to come off to change the belt or to get at the capactor. and what is the strip down thanks fasetester 🙂
April 8, 2008 at 9:45 am #248392fasetester
ParticipantRe: proline dryer
hi guy any one of the 16 engineers on line have any infomation thanks fasetester 🙂
April 8, 2008 at 11:08 am #248393wilf
its a hotpoint/creda 1703666 belt as usual
wilf
April 8, 2008 at 2:51 pm #248394fasetester
does the front panel come off the dryer to get the belt on or slip it over the back thanks fasetester 🙂
April 8, 2008 at 3:23 pm #248395wilf
take the RH side off take the top LH screw out then theres enough to check the guides and slip the belt around the drum. you’ll need the special tool to fit the belt (or a swear box ) 😉
wilf
April 8, 2008 at 5:49 pm #248396helo_75
Participantits the same dryer as a vtd
April 8, 2008 at 6:37 pm #248397Madmac
Use the old belt to pull new un over motor pulley.. it does help, honest 😉
April 9, 2008 at 3:14 pm #248398fasetester
thanks guys for all the help you were righ wilf about the swear box. and mad max using the old belt does help this is the way i went about it. took out one screw on the motor jammed two screwdrivers under the motor. then used the old belt as a tool to pull the belt on to the motor pulley. removed screw drivers put in screw might help some one else to stay sane lol rebuilt tested tumbled one way then the other put on lid job done. had to call back the dryer was running making a scraping noise when checked it was loaded like a cement mixer would over loading cause it to make a scraping sound thanks fasetester 🙂
April 9, 2008 at 3:42 pm #248399iadom
ModeratorRe: proline dryer
fasetester wrote:would over loading cause it to make a scraping sound
No, but bad design would. There is a modified drum assy with a rounded off back edge to prevent the drum scraping on the back panel.
jim.
April 9, 2008 at 5:03 pm #248400fasetester
thanks for the reply jim when i tested it was ok then when it was fully loaded it sounded like a cement mixer. does the belt have to be so tight dont think that would help is the drum kit dear or hard to fit. matters. fasetester 🙂
April 9, 2008 at 5:19 pm #248401iadom
Part number C00145650, around £36.00 ex vat list price. Not too difficult to fit.
Worth checking the rear bearing, the ultra tight belt soon gooses them as well.
You could try a couple of washers on the drum shaft on the inside first but the only real cure is a new drum. 😥
