proline dryer
Viewing 9 posts - 16 through 24 (of 24 total)
  • #252865
    fasetester
    Re: proline dryer
    thanks guys for all your input so it is a waste of time replacing these belts. is there any other dryers that have this problum breaking new belts. the are murder to get round the motor shaft. how come the first belt lasted a year or more. is it when the play comes into the drum that the belt breaks so you need to make sure before you replace the belt that it is going to be a satisfactory repair. fasetester. 🙂
    #252866
    Re: proline dryer
    I reckon it’s a combination of things on these, Fase. The belt is fantastically tight, the casing isn’t particularly rigid and I’m sure it buckles. The back bearing will send the the drum cock-eyed and as soon as the drum starts to drag everything starts to labour to keep it turning. Just a poor design.
    Quite why the pattern part suppliers haven’t done something simple like bring out an 1880H9MAEL belt, I don’t know. The extra 20mm would ease the tension a little and probably solve most of the problems.
    wilf
    Re: proline dryer
    without the special belt fitting tool you will struggle (hpt5600266) whatever way you look at it the loss of the jockey pulley was a c*** idea.
    wilf
    #252868
    Re: proline dryer
    When a belt snaps on one of these darn machines chances are the rear drum shaft bearing is also knackered. 9 times out of 10 they are a flippin’ liability to mess with. Fitting the new wider grooved belt will certainly create problems not only in fitting (the fitting tool mentioned is an absolute must for that by the way) but a week or month or two it will fail again (snap) unless the drum and bearings kit is fitted as well.
    Wrestling with these heaps of tin and plastic is a tragic mistake and best avoided IMHO 👿
    #252869
    fasetester
    Re: proline dryer
    thanks guys for the reply what would you guys do when you come across this dryer with a broken belt rrrrrrrrun. are the the only dryer that gives this problum even with a new bearing kit the can stil break the belt as you say pen a slightly longer belt a jockey pully cant be fitted as a after kit. do the condencer dryer have this problum. thanks fasetester.
    #252870
    Re: proline dryer
    fasetester wrote:thanks guys for the reply what would you guys do when you come across this dryer with a broken belt rrrrrrrrun. are the the only dryer that gives this problum even with a new bearing kit the can stil break the belt as you say pen a slightly longer belt a jockey pully cant be fitted as a after kit. do the condencer dryer have this problum. thanks fasetester.
    If only I could understand the question the chances are that helo_75 has the answer for you fase 😀
    Meanwhile steer clear of Proline Dryers my advice – I will for sure 😆
    #252871
    fasetester
    Re: proline dryer
    thanks martin for your reply. so if i go to repair one of these and the belt has snapped new bearing kit plus belt or the drum has to be changed as well. which would probably mean scrap. as all that would be the price of a new tumble dryer do the hotpoint creda give the same problum fasetester.
    #252872
    helo_75
    ok, as requested
    the condenser dryers have a tensioning pulley, thing is, theres no spring, and its rigid, and yes, they do break
    dont change a great deal of belts… im far too busy fitting fans/mod kits/heaters/capacitors/timers/pumps/rear bearings/motors
    the vented dryer idea is a bit hit and miss.. the belt is so unbeleivably tight
    my tip for the belt?
    (dont laugh)
    place the belt over your head, around your shoulders, stand on the belt, and with as much force as you can, stretch the belt as much as you can
    it does help, and makes it easier to fit?
    the common reason for the belt breaking is the fact that the drum drops of the front bearings and jams, i tend to put 2, sometimes 3 washers on the shaft to try and push the drum as far forward as possible
    best thing i would advise to the independants is to make the customer aware that the belt is a common problem, and offer to fit the belt at cost if the belt should break reasonably quickly? otherwise, you could be well out of pocket im sure if you charged them £15 just for a belt, they gotta be happy right?
    would that be fair? feedback guys?
    #252873
    fasetester
    Re: proline dryer
    thanks hello 75 for clearing that up fasetester. 🙂
