Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › proline dryer
- This topic has 23 replies, 7 voices, and was last updated 17 years, 10 months ago by
fasetester.
May 24, 2008 at 9:12 am #36934
fasetester
Participanthi guys back about six week i went to repair a proline tumble dryer. model TDV62 which needed a new belt. i am after getting a call to say the drum has stopped turning a new belt has to last longer than six weeks. and if the belt has broken again what would be the cause would over loading cause the belt to break. thanks fasetester.
May 24, 2008 at 9:47 am #252851simonb
ParticipantRe: proline dryer
this rings a bell, last time this happened the bearings had give up the goose
May 24, 2008 at 4:48 pm #252852fasetester
thanks simonb for your reply does the bearings come as a kit front and back. is the front a felt bearing and have the to be glued on. before i left the had it loaded like a cement mixer and i though i could here it make a scraping sound. does the bearing make for a good repair is there not a mod of a different drum if the bearing have gone would the drum be hard to turn and jam up. thanks fasetester
May 25, 2008 at 10:27 am #252853scots
Part No. 1703080, it comes with all you require. New shaft rear bearing , felt etc..
I have done a number of these kits and never (yet) had a recall on them.Brian
May 25, 2008 at 2:42 pm #252854fasetester
thanks brian for your reply does every kit come with the back and the front bearing. is the front glued on or does it just sit in to the recess some kits just have the bearing plate pin and other ones pop rivets is this a handy job thanks fasetester 🙂
May 25, 2008 at 4:16 pm #252855scots
you get front felt, bearing pads,shaft,rear bearing,pin, rear seal (I dont fit this) and new screws to attach the shaft to drum.
I don’t think (but not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}) this will fit to a drum with the shaft/plate riveted.
As I said I have done quite a few of these and its just about the same amount of work as the belt fit.Drum out fix the kit and rebuild
If you check on your supplier site you will see a pic of it.
There is a good pic on here which shows all the parts in the kit.
good luck
BrianMay 26, 2008 at 10:30 am #252856fasetester
thanks brian where is the pic. i dont know if this is the problum i am going to look at it today. as i replaced the belt about six week ago and the woman said it is the same drum not turning the think it is the same thing so you should be repairing it again for no charge thanks fasetester.
May 26, 2008 at 2:02 pm #252857helo_75
Participantbelts are comsumables
vacuum cleaner belts arent covered
anyway, charge her for fitting a shaft kift on it and slip a belt on while she aint looking
they do break a lot i have to say
http://shop.ukwhitegoods.co.uk/Tumble+D … t+Kit.html
is the pic your looking for
May 26, 2008 at 2:06 pm #252858helo_75
Participantoh and by the way
if the dryer was manufactured before feb 06, then the drums too big for the drier, and thats usually the reason the belt breaks a lot
you can usually tell, if when you take the drum out, you can see where its been scraping on the back panel, behind the motor over the top of the fans, its really obvious, youul see a big scrape markyou could try fitting washers behind the shaft to push it forward, other than that, its a new drum, part number 170662… around £60 +v.a.t
they really are a rubbish dryer, and are nothing more than a hotpoint vtd00/ indesit is60v in disguise
May 26, 2008 at 10:11 pm #252859fasetester
thanks helo 75 for your reply i went to see it today sure enought the belt had broken again. there is a lot of play and movement in the front of the drum. does the drum jam with the load and the motor shaft burn throught the belt. so if the dryer is pre 06 the bearing kit would make no
differience or would it cure the problum. or the only cure a new drum or dryer when you push the drum back it scrapes on the back panel what tumble dryer would you guys recommend for a fairly big family. thanks fasetester
May 26, 2008 at 10:29 pm #252860Penguin45
The only real cure is a better dryer…. Personally, I’d refund her and run away, otherwise you’ll never be shot of the cursed thing.
May 27, 2008 at 8:06 am #252861scots
Have to agree to some extent with Chris.
If I were in your shoes I would agree to replace bearings and belt at reduced cost but explain to her that they were a poor design, she may then agree to cut her costs and replace machine.Good luck
BrianMay 27, 2008 at 8:20 am #252862helo_75
Participantyep, go buy a zanussi
May 27, 2008 at 1:43 pm #252863wilf
you did fit a genuine belt I hope. 1703666 H9 wide not a pattern H7
wilf
May 27, 2008 at 2:09 pm #252864helo_75
Participantdoesnt matter what belt you fit
1701658 / 1703666 / pattern , as long as thyere all 1860 in length
they all snap, i fit probably 8-10 a week
theyre just too tight, a couple of jockey pulleys is the easy cure, but hey, they must save around £1.50 per dryer so some accountant would have said it was ok
itlll always be a numbers game, and until people realise that cheap isnt the best option, things will continue to be built cheaply, but more importantly badly
cant remember the last time i fixed a zanussi dryer
