Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Proline fridge/freezer
- This topic has 10 replies, 5 voices, and was last updated 17 years, 2 months ago by
dpr1974.
January 19, 2009 at 1:58 pm #42707
dpr1974
ParticipantI don’t have the model number yet as the customer phoned me from work, but it’s a proline f/f about 18 months old and the fridge it icing up quite bad from want she say. I was thinking many the door seal or maybe the cabinet is wonky and warm air is getting in?, the freezer is ok so unless it’s a twin compressor and one’s faulty which i would doubt being a cheap brand i’m not sure, any ideas? Thanks
January 19, 2009 at 2:00 pm #274562helo_75
Participantlol, i aint seen a proline for years with twin compressors
probably just stat, unless its a ball of ice, but like u say could be seal on door
January 19, 2009 at 2:14 pm #274563dpr1974
ParticipantRe: Proline fridge/freezer
Thanks helo_75. If it was a suspect stat then wouldn’t the freezer be playing up to?, having said that though it’s possible that she hasn’t noticed a problem with the freezer because she expects it to be how it is, Cheers. 🙂
January 19, 2009 at 2:21 pm #274564helo_75
Participantwell, not always, if stats on full, the freezer just becomes very cold….
worth a check.. turn it down, see if it clicks off, if it doesnt, then is faulty
January 20, 2009 at 12:35 pm #274565dpr1974
Well i went to see this f/freezer today, the door seal is fine and the lady has it on the lowest setting possible but it has a two inch block of ice on the back wall of the fridge. She was given the the machine when it was a week old and it been icing up since day one (18 months ago) the stat does turn the compressor off when you turn it to 0 so i suspect it had a faulty stat since new, any one agree or am i missing something? thanks
DavidFebruary 12, 2009 at 11:47 am #274566dpr1974
The customer called me back to this with the same problem which is the fridge is getting to cold, she reckons -15. So before i go back has anyone got any thoughts on this? this is the run down: been too cold ie; icing up (2″ thick on back wall) since she bought it from friends when it was a week old. compressor turns of with stat, fitted new stat, thinking that it was faulty since new, but it’s still too cold. The model number is plc55ssw or plcss55w, my Ss & 5s look the same.
David
February 12, 2009 at 1:03 pm #274567Simon46
Where is the capillary end located? on the back wall or down a tube?
S.
February 12, 2009 at 4:10 pm #274568pup
dpr1974 wrote:Well i went to see this f/freezer today, the door seal is fine and the lady has it on the lowest setting possible but it has a two inch block of ice on the back wall of the fridge. She was given the the machine when it was a week old and it been icing up since day one (18 months ago) the stat does turn the compressor off when you turn it to 0 so i suspect it had a faulty stat since new, any one agree or am i missing something? thanks
Davidhas it got a stat or is it pcb
February 12, 2009 at 6:03 pm #274569dpr1974
No pcb just a stat and the end goes down into the back wall via a tube. There was one thing i didn’t recognize which was next to the compressor, it was a white plastic box and inside that was what i would describe as a smaller white box shape object with what look like a little steel dome attached on the side, look a bit like a bike bell and on another side was a dial that needed a screw driver to turn it.
David
Fridge/Freezers are not my strong point give me a washer, t/d or cooker anytime 😀
February 12, 2009 at 6:41 pm #274570boselecta
ParticipantSounds like your describing the defost timer. This could be the fault, could be overiced, have you checked the normal frost free functions, heater, fan, stat or blockages etc.?
Cant remember this appliance is the evaporator top mounted or behind the freezer back wall?February 12, 2009 at 9:45 pm #274571dpr1974
Checked all those except the timer as i didn’t recognize it (only dealt with the big chunky black units before) like you say that could be the problem in that it’s not advancing onto the defrost cycle, also the evaporator is behind the back wall and it’s a stat not a pcb. Thanks for the help, looks like i might be dealing with a faulty defrost timer. Some people amaze me, this machine has been like this since new (over a year ago) yet they never had it dealt with under warranty?? 😕
David
Edit: a faulty defrost timer would explain the ice build up but would it also cause the -15 in the fridge?
