proline/ocean freezer
  • #17867
    abbots
    hi guys,
    upright proline/ocean freezer FF959 Sn. 010411331
    evaporator fan motor part no. please.
    thanks , john
    #176735
    Dave_Conway
    Re: proline/ocean freezer
    Brandt part number 45X8108 🙂
    #176736
    abbots
    thanks once again dave.
    john
    #176737
    abbots
    hi dave,
    just had fan motor delivered and its not the right one,the one sent is the old type for the rear mounted ocean fan motor,and the shaft isn’t splined.any chance you can check part no’s for me please.the one i need is situated in the evaporator cavity and is held on with 2 metal brackets.
    john
    #176738
    Dave_Conway
    Well, it’s manufactured by Brandt and that part number is the only one listed against that model, it hasn’t been superseded either so something’s odd about it 😕
    The picture definitely shows the two brackets as well.
    I don’t know where you got it from but Connect’s site have a picture and as you say, no splines. An enquiry through them or Masterpart may come up with an alternative but I can’t find one…….
    #176739
    abbots
    not to worry,
    i got it off connect so i’ll have a word with the rep. see if he can help.
    john
    #176740
    abbots
    hi dave,
    just thought i would keep you informed.
    went for another look at this freezer.
    took old fan motor out and it is made by a different manufacturer than the replacement you gave me the part no. for,but they are interchangable,you just have to swap the brackets holding it on with the old ones.
    thanks for the help,works a treat now.
    john
    #176741
    Dave_Conway
    Thanks 😀
