Proline PDW080 Timer stopping in mid program
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Proline PDW080 Timer stopping in mid program
  • #41956
    typhoons
    My 2 year old Proline PDW080 pumps out, fills, heats the water, circulates the water through the bars, then stays at this point forever!
    The Timer stops in the same position each time, and the usual noise from the timer stops also. If I advance the timer 1 notch, the dispencer opens and the machine then completes the cycle.
    I have fitted a new timer, but the problem has not gone away. I get the impression that the timer may be waiting for an input ( temp?), but I’m not sure.
    Any advice would be gratefully received!
    Re: Proline PDW080 Timer stopping in mid program
    Almost certainly a timer fault. The sequence for the heated wash sequence should go drain, fill, circulate, “clunk” as the dispenser opens, then heat. The mechanical timer will stop for the heating phase, then advance when the thermostat completes the circuit.
    Unfortunately, this is the usual shoddy Chinese stuff, so weigh up how much you want to spend to repair it – a timer is likely to be £60+, then VAT……
    That nice Helo_75 may be able to advise you further as he deals with these most days.
    typhoons
    thanks for the reply, but the timer is brand new! It seems strange that the new timer is stopping at exactly the same position as the old one ( I marked the position on the outer dial). Would there be anything that would cut off the supply to the timers drive at this position?
    #271838
    Probably…… Wait and see what Helo says. Anything is possible with the Haier dishwasher!
    helo_75
    theres a cut out…. just at the back near the heater… thats the usual suspect
    its screws int the cabinet
    a simple continuity test will prove its function
    #271840
    Mornin Helo..
    What you doin outta bed at this time of the morning..She kicked you out already 😆
    Bryan
    #271841
    helo_75
    got a very bad case of gout, and its doin my head in
    had it a week now, and its just startin to go away
    and im still working, even with a bad foot
    mind u , your up early too!
    #271842
    This early
    Nooo just goin out the door,my first call 5.30 in north london
    Bryan
    #271843
    typhoons
    thanks for the reply, I found 2 conponents that screw into the undeside of the machine, marked KSD 201. Both tested ok for continuity. what I did notice is some burning around the element, but it was not open circuit ( 90-100 ohms).
    Is there a temp sensor that I can test, as I think the element is working ‘of sorts’!
    typhoons
    I’ve removed the element and found ot burnt out on the corner.
    Thanks for your help
