Proline PDW081S lights on, nobody at home
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Proline PDW081S lights on, nobody at home
  • #34046
    shuff
    Not sure what part I need, hope someone can help.
    Was doing the short wash cycle and smelt a burning smell but had to go out so I switched the dishwasher off to check it out later. When I returned I switched it back on, the power light came on but the dishwasher wasn’t working.(not draining/washing/anything) Is it the main motor? Is it the same as the circulation motor?
    #241013
    Re: Proline PDW081S lights on, nobody at home
    Oh, come on…….. crystal ball time? If you want to do this yourself, you’re going to have to get the screwdrivers out and have a look.
    Chinese jobbie though, so is it really worth bothering with? Put ‘Haier AND dishwasher’ into Search for this forum only for an idea of what you’re up against.
    Pull the plug if you are going to have a look.
    shuff
    I know, don’t shout. At least I’m a lady who wants to get the screwdrivers out and mend the damn thing.
    I take it from that, ‘bin it’
    #241015
    Er, it’s not very good……..
    Problem is these things tiddle water into the bottom with alarming regularity – as soon as things get wet, just about anything can blow. Parts supply is a problem, cost of parts in relation to the cost of the appliance is not good and whilst it can be made to work, you can’t make it better…….
    If you fix it, there are a few ‘does and don’ts’ – never use multi-function tablets in one of these. Powder or Fairy Bursts only; these are low froth products. Once it’s running, never, ever open the door until it’s finished.
    These machines cost £45 on the docks in China – it’s a dead easy way for Comet to make £100! Sorry, but you will get what you pay for.
    Shouting? No – we turn the Caps Lock on for that 😀 .
    franz
    Repaired one of these today – same fault – door microswitch at fault – this machine is an old indesit design – part number for switch is c0041194- Remember to unplug it first.
    Franz
    #241017
    shuff
    Franz, thanks, where can I get the part from?
    #241018
    An email to spares@ukwhitegoods.co.uk will do the trick.
    shuff
    Forgot I’d saved some parts from my old indesit dishwasher and what do you know, same switch so Proline all fixed.
    Thanks for the advice, would never have thought someting so little could cause such huge problems. The switch I took off was totally burned out so I’ll know next time.
    Taa
    #241020
    thomasshop
    has anyone got a manual for a proline DW6006 or knows where i can download one ?
    Many thanks
    Karen
    #241021
    Proline is a Comet brand, so you would need to contact them.
    RainyYu
    Penguin45 wrote:Er, it’s not very good……..
    Only cost £45 for PDW081S? That is really a good business for Comet.
    #241023
    RainyYu wrote:Only cost £45 for PDW081S? That is really a good business for Comet.
    Correct – what is your interest?
    RainyYu
    The margin for retailer is quite high.
    It seems a good opportunity to be a dishwasher importer and exporter. :rolls:
