Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › proline TDC6A heating problem
- This topic has 9 replies, 5 voices, and was last updated 20 years, 2 months ago by
comstadcity.
February 7, 2006 at 12:22 am #15450
comstadcity
ParticipantHello, I wonder if anyone can help me with some advice. My condenser dryer doesn’t get any heat. I have checked the 2 thermal cut outs on the rear of the machine and they both have continuity when there is no power. I have also checked the heating elements for continuity and they too are fine, likewise the thermal cut out that is just above the door also has continuity. When the machine is running there is no voltage going to the heating elements or to the 2 thermal cut outs on the rear of the machine. I have made sure that the water tank is empty and I have removed the side and back panels to check that the level sensor is working ok, which it is. What can I check next? could the timer possible be faulty? Any suggestions would be gratefully accepted. Absolutely superb site by the way. Peter Eastwood
February 7, 2006 at 12:25 am #163638Penguin45
ParticipantRe: proline TDC6A heating problem
Did you take the stats out of circuit when testing? If you don’t you get a back reading through the heater.
Penguin45.February 7, 2006 at 6:30 am #163639comstadcity
BLIMEY, that was a quick reply. to answer the question, yes i disconnected the wires from the stats so that the stats were isolated.
February 7, 2006 at 7:15 am #163640bobokines
Please be very carefull when checking live machines. :zap: We always advise that you check for continuity from the plug top rather than testing for mains voltages. :plug:
The timer is the only other component in circuit so I would agree here that the timer is your next step. It’s not very common though, so double check all the stats first! The heater is only in circuit during forward tumbles by the way.
Bob
February 7, 2006 at 7:30 am #163641comstadcity
Thanks, will recheck all the stats when i get home from work today just to make sure, although i am pretty certain that they are not at fault. If I have to replace the controller/timer will one be available from this site and how much would one cost.
Thanks to every one who has tried to help.
February 7, 2006 at 8:22 am #163642Dave_Conway
Yes, we will be able to supply 🙂
There are two though dependent on the serial number so we would need to know this please.
February 7, 2006 at 6:33 pm #163643comstadcity
Hello, All of the stats on the machine + the level sensor and the heating elements check out ok again. One thing I have noticed is that the water tank full light is illuminating very dimly, infact it is only noticable when the kitchen light is turned off, in normal light it is not noticable. Do you think that the timer/controller is the most likely cause of the problem? if so I will need a price for a new one. The s/n of the machine is 08101304.
once again thanks for the help, peter
February 8, 2006 at 8:32 am #163644Dave_Conway
Part number 1702508 at £22.51 ex VAT and carriage.
An email to spares@ukwhitegoods.co.uk please if required 🙂
I’ve deleted your other new post relating to the same 😉
February 8, 2006 at 7:56 pm #163645comstadcity
Many thanks for your help. I have sent the E-Mail and will await ordering instructions.
May 27, 2012 at 7:38 am #163646Steve1956
Hi new to the site! I note these posts were issued 2006
Did anyone find the problem to this issue cause my proline
Is displaying a very dim water full light and not heating. Everything
Seems to check out ok ? -
