PTC Relay – rated 33 Ohms ?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum PTC Relay – rated 33 Ohms ?
Viewing 1 post (of 1 total)
  • #83668
    KBCFC
    Question for you all please…
    I have a PTC Relay on my Samsung side by side Fridge Freezer – RSA1WTMH.
    I can see the part code on the relay that fits onto the compressor, with the thermal overload, is PTHTM33OMD3
    The data sheet for the part shows a resistance of 33 Ohms.
    I have a non running compressor on my unit and I am wondering if the PTC Relay is at fault and hence why my compressor is not kicking in at all.
    Upon measuring across the 2 terminals on the relay I am getting around 1500 Ohms.
    I am trying to rule the relay in or out, as far as being responsible for the non running compressor.
    Anyone know what resistance I should read across the terminals of this PTC relay when it is removed from the Fridge Freezer and tested for resistance ?
    Any help or advice would be appreciated.
    Kevin
