Re: Puddle beneath Britannia Nebraska FF
This is a GE made appliance and a common fault with this is that the pipe from the water valve becomes brittle over time and cracks.
If this is the case, then you need a new water tank which comes complete with the pipework.
The ‘pond’ of water has nothing to do with the pipework at all but is obviously in the same area.
Look around the water valve and at the bottom, probably 4 to 6 inches away from the valve, the pipework will most probably be yellowed and brittle.
