Pumping washing machine water from basement?
Home Forums General Trade Forum Pumping washing machine water from basement?
  • #9122
    andy_art_trigg
    What are those devices called and where can you buy them? The washing machine pumps water into a tank which then triggers a powerful pump to pump the water up to ground level from a basement?
    #132468
    Re: Pumping washing machine water from basement?
    Saniflo?
    #132469
    dpm
    Or just an ordinary submersible pump w/float switch (Lidl were doing one cheep a week or two back…) sitting in a small water tank/ barrel?…
    #132470
    clivejameson
    …or buy a proprietory macerator…designed for toilets but pumping away wash water would be a piece of….er…..cake 😉
    #132471
    andy_art_trigg
    Thanks. I’ll look into those suggestions.
    #132472
    Many years ago I rigged up something for a local chap with a Top Loader that was below ground level.
    He supplied a full size plastic drum, the size of an oil drum and a fish pond submersible pump.
    I fitted the full pressure switch, hose and chamber from an old machine and adjusted the levels so that it tripped when the drum was just over half full then reset when almost empty. It had to have water covering the pump to keep it primed.
    It was very much a tribute to Heath Robinson, but it worked for many years.
    #132473
    andy_art_trigg
    Nice one. I rigged up a more crude but equally effective system in my workshop to water test machines. I fitted a shelf about 6 foot above where the machines were to be water tested. I drilled a hole in a normal water tank (found in lofts) in its side as near to the bottom as possible and sealed a sump hose into it. I fitted a Hoover pump at the end of the hose. The drain hose from this pump went a further few feet higher and into half inch waste pipe which went about 20 feet right across my shop and into the waste pipe in the sink in a corner.
    The pump was permanently plugged in to a socket with only the neutral connected and the live was just a long lead with a crocodile clip on the end.
    When testing a washing machine I just clipped the lead onto the live of the washing machine’s pump, and each time the washer pumped out it also supplied the tanks’s pump. The water pumped into the tank, drained into the second pump and was pumped another few feet up to the waste water plumbing.
    I was well chuffed with that 🙂
    #132474
    The trade standard system most plumbers fit:-
    http://www.saniflo.co.uk/San_Products.asp?name=vite
    Lawrence
    Machine mart have got submersible pumps on offer at the mo
    Lawrence
