Quality drum bearing kit
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Quality drum bearing kit
  • #101656
    Wt960g
    Can anyone advise where I can purchase a good quality bearing kit. Nsk timken etc tia. For a hotpoint Wt960g
    #485598
    you could fit the gen set which might be
    https://shop.ukwhitegoods.co.uk/c00202418-washing-machine-bearing-kit
    if the shaft is 35mm
    some units used a 30mm shaft and there is no easy way to tell although the 30mm often had plastic pulleys
    also due to spider corrosion its advisable to strip the unit and check the spider first
    Wt960g
    Thankyou for reply. I see their are lots of kits for sale from different sites with various prices. I will follow up your advise. Eric
    #485600
    if you want Better bearing you could always find a local bearing supplier and get 6206 and 6207 bearing but you still need the seal which is special to this range of washing machines . if it is a 30mm shaft it uses smaller bearing and another seal
    the gen kit does use a rubber shrouded bearing but i dint think there is a weep hole in the rear drum half so it makes no rael difference
    as said before check your spider first and if you go ahead pay careful attention to the wiring harness as they rub on the concrete weights if badly routed
