Re: Query on Tricity Sovereign oven
This is not normal as far as I can remember.
The cooling fan has an initiation stat, wont come on until around 60 degrees in the air space arond the timer. The oven fan and heat are controlled by the timer and if you are refering to the fan oven motor running on after shut down of the stat you need to investigate.
The wiring all runs up to the timer and it won’t be hard to trace the fan oven outputs and check.
I think the timer is obsolete these days.
Kevin
