question about bosch motor armature/commutator
Home Forums Public Support Forums Help And Support Washing Machine Help Forum question about bosch motor armature/commutator
  • #41142
    smcilwain
    my bosch wff2001 motor has stopped turning again aftyer filling with water.
    I only replaced the brushes a year and a a half ago. THere is still just under 1/2 inch carbon on each brush.
    Someone suggested that the armature might be worn. How can i tell if this is the case please. Obviously I don’t want to order new brushes if I really need a new motor! Will new brushes get more life out of worn commutator.
    I am going to try replacing the brushes again anyway, but do I really need a Washing Machine Motor Commutator Cleaner (they are more expensive than the brushes!) would a cleaner help if my armatare is worn? – or could I not just clean the commutator with some super fine abrasive paper.
    Any speedy replies welcome as I need to order the brushes if that will suffice.
    Many thanks in advance
    SM
    #268933
    smcilwain
    Re: question about bosch motor armature/commutator
    Just a quick bump.
    Can anybody shed any light?
    Thanks again ❓
    #268934
    When the motor is new, the commutator is flat. As the brushes wear, they wear the surface of the commutator into a groove. If the groove is particularly pronounced, the new brushes have difficulty seating properly and tend to be a bit “sparky”. This causes them to wear rapidly.
    Giving the commutator a wipe over with fine emery won’t do any harm.
    smcilwain
    Thanks Penguin. Much appreciated. Do you advise the special cleaner??
    Thanks again.
    #268936
    No, I’ve never used the stuff.
    Penguin 45.
