Question for Indesit employed engineer?
Home Forums General Trade Forum Question for Indesit employed engineer?
  • #22674
    You are called to a Hotpoint WMS38P that is under 4 years old. It’s located in the back of a garage next to a Hotpoint dryer (same vintage) and chest freezer. It is cold and the atmosphere is damp, no lino on the bare concrete floor either!
    You check the machine to find the usual ‘door lock light flashing’ 🙁
    You find the module, motor and interlock all covered in moisture. The motor reads 5 megohms on the meter, not looking good huh?
    So, my question to you Indesit employed engineers: – Would you honour the 5 year parts warranty and stick a load of new bits in it for labour only?
    #195797
    cornwell40
    Re: Question for Indesit employed engineer?
    Had one in the basement of a dry cleaners years ago when I worked for Hotpoo. Early WM range, rotten from the inside out within two years cos of the moisture down there, (also covered in cockroaches and hemmed in with bed mats, people slept down there I kid you not) which was I/G and on a D and G insurance. Both went for the repair no problem even though I’d reported it to both parties on two occasions. :con:
    Doesn’t exactly answer your question but you’d think things would have changed…………………………….wouldn’t you?
    Tony C
    #195798
    gegsy
    cornwell40 wrote:………(also covered in cockroaches and hemmed in with bed mats, people slept down there I kid you not) which was I/G and on a D and G insurance. Both went for the repair no problem even though I’d reported it to both parties on two occasions. :con:
    On a health and safety aspect, surely the appliance should have been condemned. They shouldn’t of expected you to work on an appliance in an infested room 😯 dirty beggers 👿
    cornwell40
    It wor proper nasty 😥
    The new blue Hotpoint uniform I had back then was black when i came out, I was completely drenched when I came out, as you walked downstairs to it the humidity crawled up yer legs. I had to walk about four blocks back to the van squelching as it was central London.
    Tony C
    (PS Sorry for hijacking your post with me story Martin 🙁 )
    #195800
    Gertrude
    I’d’ve thought that unless there are specific instructions obviously noticable to the customer regarding installation siting and relevant conditions then you’d have no choice but to honour the parts guarantee.
    Cockroaches! 😡
    Have to be firm and say ‘No!’ to working anywhere that has these.
    #195801
    Gertrude wrote:I’d’ve thought that unless there are specific instructions obviously noticable to the customer regarding installation siting and relevant conditions then you’d have no choice but to honour the parts guarantee.
    Indeed so I agree, however whilst the installation instructions make reference to connecting it to approved electrical connections and the correct plumbing requirements. They suggest only to “seek professional advice if you want to install your machine in a bath or shower room.” But it makes no mention of unsuitable locations such as outhouses,sheds and garages. 😕
    That is why I was hoping for some clarification from an Indesit employee as Hotpoint further add “You may be charged for the service call if a problem with your machine is caused by incorrect installation or misuse”.
    We all have come across many such cases of machines installed in unsuitable environments such as this in the past. The older generation of machines that didn’t rely on electronic control systems did cope very well and with no problems. One sniff of dampness with these modern gizmo’s and its Goodnight Vienna!! 😥
    But would it be fixed under guarantee eh Indesit?
    #195802
    SDR
    i would fix it on the condition it was moved before further use, if they would not move it i would fix it and charge the buggers 😆 thats cos im a franchise not employed .
    #195803
    recall
    theres a specific clause in d+g ins that voids it on corrosion so i guess that indesit would come up with the same answer.
