Home › Forums › Public Support Forums › General Enquiries And Questions › Quick question about intergrated washing machine fitting…
- This topic has 4 replies, 2 voices, and was last updated 16 years, 8 months ago by
CheekyThomas.
July 31, 2009 at 9:09 pm #47495
CheekyThomas
Im currently having a new kitchen installed, and have a space for a integrated washer dryer… The units are a standard 870mm in height, and the space is 600mm wide.. however its the depth that concerns me?
The units are 570mm deep which seems to be a rough normal size… the integrated dishwasher and fridge all seem to be fine, but the washing machine confuses me…
In the catalogue it states its W600 H820-870 D555
But the actual booklet with the machine says the machine is actually W596 H818 D541 so that looks promising as it should fit in the gap…
But then on the installation diagram it shows a empty unit with recommended fitment measurements as W600 H820min D600
So im now thinking it wont fit as my unit is only 570mm deep not 600mm like the fitment instructions… do i need to space my units further from the wall??
I assumed most common integrated appliances would be interchangable?
August 1, 2009 at 7:49 am #293649don
ModeratorRe: Quick question about intergrated washing machine fitting
Some variation there then 😆 if you can let me know which make and model it is I `ll look into it for you.
Don
August 1, 2009 at 8:49 am #293650CheekyThomas
ParticipantRe: Quick question about intergrated washing machine fitting
Its a AEG 12843VIT integrated washer dryer.
August 1, 2009 at 8:52 am #293651CheekyThomas
If you can also chase up hotpoint on the OS897DPIX oven and see when they should be coming available as this missus is waiting to order one…
August 1, 2009 at 9:34 am #293652don
CheekyThomas wrote:Its a AEG 12843VIT integrated washer dryer.
Checked through the AEG website and all spec leads to 820 high (adjustable) 600 wide 541 deep.
CheekyThomas wrote:If you can also chase up hotpoint on the OS897DPIX oven and see when they should be coming available as this missus is waiting to order one…
Still not listed on Hotpoint ordering system, so no due date as yet I`m afraid.
HTH
Don
