Ranco freezer thermostat
Home Forums Public Support Forums Spare Parts Help Ranco freezer thermostat
  • #6210
    Jaded
    Hotpoint built-under freezer model 6956 (1997ish). Thermostat is a Ranco with a no. on K54-H1118/001 There is a British company based in Northampton offering a thermostat identified as a Ranco K54H1101001 at what seems to be a very reasonable price. Does anyone know if the two are compatible?? P’se.
    #116339
    Dave_Conway
    Re: Ranco freezer thermostat
    It should be OK, as the K54 part denotes the switching temperature, the rest is to do with the length of the capillary.
    Out of interest, how much is “very resonable” ?
    #116340
    hi,
    if your freezer is completely dead it MAY need the stat, however a 97 freezer not cooling correctly is more likely to be a system…and will almost certainly be R134a gas, is the compressor (the motor) warm/hot to touch and is it running? If so might not need the stat
    kevin
    #116341
    Jaded
    Kevin – hello.
    The freezer has a ‘fast freeze’ button. When this is pressed the freezer runs and within an hour or so the thermometer will get down to c-18. With the ‘fast freeze’ released the temp gradually rises and we could smell ‘cheesy feet’. (We lost a lot of food). I took out the thermostat and there was no continuity between the live terminal (brown) and either of the other two terminals ( black x2, and blue x1) at room temperature. I have ordered a new ‘stat and am keeping my fingers crossed. Any thoughts will be welcomed.
    #116342
    sounds as though you are ok, if the fast freeze achieved -18 then system is ok.
    regards
    kevin
    #116343
    Jaded
    Kevin – thanks 🙂
    😥 The repacement stat from Coolfreeze of Northampton arrived this am. They have supplied the wrong one. Someone cannot read the difference between RAN54 and VC1; and there is only an answering machine. Have you ever had that sinking feeling…………………?
    Does anyone know of a reliable supplier of a Ranco K54 stat?
    #116344
    Dave_Conway
    Jaded, a Ranco K54 is a VC1, it’s the same thing.
    Ignore this post as it is totallly incorrect ! 😳
    #116345
    Jaded
    See private message (if I can manage it).
    #116346
    Dave_Conway
    Yep I got it 😀
    I don’t quite know what plane I was thinking along there, a K54 is a freezer thermostat, a VC1 or K50 is a fridge with ice box thermostat.
    My appologies 😳
    You are of course correct, they have supplied the wrong thermostat, they should have supplied a Ranco VS5 or equivelent.
    #116347
    Jaded
    Thanks again.
    I’m still left wanting a reliable source for a Ranco K54 (or equivalent), so if anyone out there knows……….?
    #116348
    Dave_Conway
    I got loads, PM me your details and I’ll sort one out for you. Measure the length of the capillary and I’ll try and match it with the nearest I have.
    #116349
    Jaded
    Dave – thanks.
    PM on its way
    #116350
    Jaded
    The new K54 you supplied is in, fitted ok, and seems to be working fine. Senior Management is pleased, which of course brings a number of fringe benefits. What a pity I saw the Coolfreeze web-site first. I’m still sore about them.
    Rgds
    J
    #116351
    Dave_Conway
    Jaded wrote:Dave
    The new K54 you supplied is in, fitted ok, and seems to be working fine. J
    Thanks for letting me know 😀
