rangemaster 100 thermal cut out!!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum rangemaster 100 thermal cut out!!
  • #78074
    tracyp74
    Help please!!! My rangemaster 100 cm10frc right hand side oven igniter and hot plate are not working, I have bought a replacement thermal cut out as the one in at the moment has blown and is no longer wish so had to buy the new version however this is completely different from the part being replaced and I would like any help in how to fit it and what to do with the old one as this wire is very long and goes round the back to the other side of the oven…the part I bought was 210110544 any help photos or info would be really appreciated
    #404371
    Seamy
    Re: rangemaster 100 thermal cut out!!
    Power off first of course…
    Easy way around it is to cut out the original thermal cut-out which I believe may be crimped in the loom, fit 2 spade connectors on the cables cut, fit the cables to the thermal cut out that you now have, there should be a fixing point to the side of the oven that the bracket will attach to, any local engineer worth his salt will have done loads of these & will do it if you don’t feel competant.
    The part needed is actually 4410101001 which includes cable & connectors etc.
    #404372
    tracyp74
    Thanks for your quick reply.. will I be able to use the thermal cut I have bought? It did come with a spare connector so I could just use this and get another one
    Many thanks
    #404373
    Seamy
    yes
    #404374
    tracyp74
    Thanks very much its now all working and I did it myself at a cost of £8.00!!! Slightly betting that the company I called who wanted £75 just to have a look! !
