Rangemaster 110 6106001110 fan oven element
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Rangemaster 110 6106001110 fan oven element
  • #15823
    Simon46
    Where can i get one of these? Is it a front fitting or cooker out job?
    Regards
    Simon
    #166495
    Dave_Conway
    Re: Rangemaster 110 6106001110 fan oven element
    The Zanussi 3 turn fits these, through the oven if you’re carefull that the leads don’t fall off 😉
    #166496
    Simon46
    Thanks Dave. Apologies for double post. Keep getting website not responding. 😳
    S.
    #166497
    Dave_Conway
    No probs Simon, the site has been slow on and off all day 😕
    #166498
    The Gen number is A030203 and is only £9 odd from electrue and you get a new gasket with it!
    The usual problem fitting these is the earth wire dropping off which needs the cooker pulled out to re fit. You can often see the tag hanging just behind the hole (which is a soft metal plate behind the oven back) if you enlarge this with a slotted screwdriver to enable the tag to be pulled through with a fine point long nose pliers it will save a lot of effort.
    #166499
    Simon46
    Yes can they make the holes any smaller. Used a needle to fish wire through after reaming hole with drill.
    Thanks all. 🙂
    S.
    #166500
    whitevanman
    Thanks all
    the manufacturer has now made a larger holes on new models hope this helps for the future
