rangemaster 110
  • #30935
    hilly
    the clock will not set and it is stuck on auto. i am assuming i have to replace the clock. just thought id mention it on here b4 i splash out on the clock incase something else could cause this fault?
    thanks paul
    #228986
    gegsy
    Re: rangemaster 110
    You could look for dry joint on pcb of clock and check continuity on button contacts, re- grease ingress 😀
    Failing that new clock or link switching wires for oven from clock if customer ain’t bothered about clock display and timed cooking.
    hilly
    Re: rangemaster 110
    cheers gegsy, new clock then i guess. they still want timer cheers for post 😆 😆
    #228988
    gegsy
    Re: rangemaster 110
    If you stick model up (remove r/h warming drawer completely and look on the r/h chassis strut, should have 4 digit number 5???) will try and get p/no 🙂
    helo_75
    if its one of them naff beko versions, i think youll find if you push the clock back together, itll work fine
    #228990
    gegsy
    Re: rangemaster 110
    This is a genuine decent one.
    The main fault with the Beko ones (range or cooker) is the clock dead/no main oven. Thats down to the thermal fuse of the cavity blowing as its under rated. 😉
    hilly
    Re: rangemaster 110
    thanks for replies ive not been on for a few days but ive got a clock on order thanks
