There’s been some spillage down the back which has found its way into the box and shorted the pcb. There’s no supply to the fan oven main switch and also the customer did complain about the constant humming from the cooker when not in use which I took to be the cooling fan.
Thanks for the reply
Rick
Still having great diificulty getting this part number. Connect have drawn a blank. This module is about the same size as a stick of pc ram with half a dozen or so wires soldered to it. Help would be much appreciated.
Rick
Ok , finally found part number after many phone calls. Thought it may come in usefull for anyone else that comes across this one. Module PCB cooling fan FVLP027589
Rangemaster spares can be obtained from their agents http://www.graffters.co.uk . Their phone no. if you don’t want to phone them on the 0845 no. is 01483 741681.
