Rangemaster 110 Clock/Timer Renewal – Eectric – 53440041
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Rangemaster 110 Clock/Timer Renewal – Eectric – 53440041
  • #71488
    jontymox
    Good evening all,
    Wondering if one has to remove the above unit in order to remove and replace the clock/timer unit?
    Had a brief look when confirming clock/timer u/s, and unsure on front panel removal procedure to access above.
    Does one need to pull the unit completely out to access further screws at rear of unit, or can one renew clock/timer more readily?
    Any help much appreciated.
    Jon
    #381265
    Re: Rangemaster 110 Clock/Timer Renewal – Eectric – 5344
    by electric youmean solid plate or ceramic? either way I think you need to get to the screws at the rear.
    #381266
    boselecta
    yes as mark says you have to remove two screws behind ceramic plate, if it has a lid, they are only exposed when you lift the lid.
    When you have taken the screws out you have to slide the plate to the left to lift it off.
    #381267
    jontymox
    Thanks Gents,
    Yes, it’s a solid plate type.
    Will remove appliance to access screws, and gain access to timer.
    Kind regards,
    Jon
