rangemaster 110 electric solid plate
Home Forums Public Support Forums Help And Support Cooker And Oven Forum rangemaster 110 electric solid plate
  • #22680
    burnett
    I have a problem with the fan oven staying on. I am guessing the switch/thermostat is stuck on. Can anyone tell me how to get to it to change it, or if I’m totally wrong? Thanks
    #195832
    Re: rangemaster 110 electric solid plate
    The hobs have to come off, not really a diy job. Do you mean the whole oven stays on (ie heat and fan)? or just some heat and the stat light on.
    #195833
    burnett
    Just the heat, the fan goes off.
    #195834
    burnett
    Adding to that, the heat is on full all the time once the clock is set when it’s switched back on. if the stat light is the one by the switch? thats on
    #195835
    burnett
    Would appreciate some clue as to the way to remove the hobs.
    #195836
    burnett
    OK now found it, two screws under griddle and then slide out end ways
    Cheers
