Rangemaster 110 Fan element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster 110 Fan element
  • #11288
    therons
    Hi Guys,
    I have just received my fan element for my rangemaster,I bought it from the uk whitegoods shop@ fantastic service 😀 ordered thursday arrived this morning :tup:
    so please please please could someone tell me do i fix the new part by working inside the oven??or do i have to pull the oven right out and work from the back?
    thanks Dean
    ps….I will disconnect it from the mains 🙄
    #144664
    Re: Rangemaster 110 Fan element
    Remove inner rear panel of oven cavity to reveal the element. If you can see screwheads, you fit the element from the front. If you see hex heads, the element will be retained by nuts from the rear.
    As you have said, power off……….
    therons
    Thanks Penguin,
    Iwill let you know how i get on
    all the best
    Dean :tup:
    #144666
    farmboy
    The element is screwed in from inside the oven cavity but you will most likely find that as you pull the element forward the connections will come off the back as the holes in the cavity arent big enough to cope with the connectors. This means that once you’ve changed the element from inside youll then need to pull the whole cooker forward to access the back panel screws & reconnect. Not too bad a job just a pain when you have to drag the whole cooker out.
    #144667
    therons
    yeah your right Farmboy,
    I removed the screws from the element but it did’nt move so i pulled the cooker out,once i had the back off(only about four screws)and a bit of wiggling the element came out 😀 .
    Put the new one in :tup: and now the oven heats up fine.
    Thanks for your help lads :beer:
    all the best
    Dean
