Rangemaster 110 fan oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster 110 fan oven
  • #89461
    mike kin
    The oven won’t go above 180c .it stays on but just won’t get hotter. Door seal looks fine. Does anyone have advice please. Im think of thermostat ?
    Be most grateful for help.
    #441445
    Re: Rangemaster 110 fan oven
    Sounds like a stat issue if it’s using the fan oven mode.
    If it’s a static oven or used in static mode then it could be the upper or lower element, which would be more likely with that sort of report ordinarily.
    mike kin
    thanks. what do you men by static.? its a fan oven its sometimes creeps slightly above 180c but always falls back
    #441447
    A lot of them are multi function ovens that can be used in different cooking modes.
    mike kin
    this is just a fan oven. does nothing else
    #441449
    Lawrence
    Thermostat
