We have inherited a Leisure rangemaster 110 when we moved into our house 1 year ago. The Rangemaster is only 2 years old, but the fan oven has just started not to heat, although the fan works ok.
Fan element no doubt open circuit. A pretty straightforward repair but if you’re not sure try Repairs at or the directories for a local repairer or put up your postcode area and we’ll try to help.
Re: Rangemaster 110 Fan oven not heating though fan working
Might be worth contacting Rangemaster on this one, they changed the elements from 2 turn to 3 because they were failing. To change the fan element on one of these normally requires pulling the whole cooker out.
