Rangemaster 110 gas blows fuse when left oven switched on
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster 110 gas blows fuse when left oven switched on
  • #90258
    Hermaj
    Rangemaster 110 all gas, if I use the left oven it blows the trip fuse in the wall, the spark to light the ovens doesn’t always work , and sometimes it makes a buzzing/crackling noise instead of lighting oven, really need both ovens and can’t afford a new range 😥
    #444202
    Lawrence
    Re: Rangemaster 110 gas blows fuse when left oven switched o
    You have a fault that requires an engineer,its not a DIY fix sadly
    #444203
    Hermaj
    Hi Lawrence
    Thank you for replying, I have a gas engineer to do the work but he’s not sure what part is needed so if anyone here can tell us it would be a great help as parts are so much I don’t want to get the wrong thing if possible
    #444204
    The gas engineer needs to find out what part is tripping the electrics. At that point if he knows what he is doing should be able to obtain the parts for you..But the majority of Gas engineers who do boilers and installations don’t actually know anything about repairing appliances.
    It’s down the your gas engineer if he’s compident to find the fault.If he can’t then you need a gas appliance engineer.
    Where do you live ?
    Bryan
